How can I quickly copy group addresses?
mjaanes
Oläst inlägg av mjaanes » 16 apr 2017, 15:38
Is there a quick way to copy 5 group addresses to 5 communication objects so that they get connected one-to-one respectively?
Example: Very often, a device (e.g. a dimer actuator or a Dali gateway) will offer five communication objects (typically switch, dim, value, status, status value) and typically, you will have created five consecutive group addresses that correspond to the communication objects (e.g. 1/1/0=switch, 1/1/1=dim, 1/1/3=value, etc).
What would be convenient would be to “drag” all five group addresses over the switch’ communication objects so that each of the switch communication object are linked to each of the switch group address, i.e. the dim communication object is linked to the dim group address, etc).
Do you know of a quick way top do this?
Thanks in advance
Re: How can I quickly copy group addresses?
Oläst inlägg av Rikard Ågren » 16 apr 2017, 22:34
The fastes way I know of is by assigning a keyboard shortcut to the add assignment-function. It will automaticly choose the next group adress with datatype compatible with the group object in question and thus you dont need to use the mouse
Jobbar med PLC och KNX i större fastigheter.
mjaanes
Oläst inlägg av mjaanes » 22 sep 2018, 09:56
Takk (litt forsinket...). Har foreslått dette som en ny feature til ETS.
Hilsen
Christian
tokatubs
Oläst inlägg av tokatubs » 23 sep 2018, 00:14
This is what the app "extended copy" from KNX.ORG is for.
You set up one product with all the addresses that you want for switch, value etc.
And of course make the links for the right group addresses. With lets say Switch Living room, Value Living room.
Then you copy the product and click paste extended.
Then tou get a whole lot of options. The you just choose exchange text. From Living room, to "your new room".
Ets then creates a whole new product with all new group adresses.
In big facilities with offices with rooms like 301,302,303 it is even more easy. Then you just choose running numbers and ets will create like 10 products with corisponding group adresses with a click of a mouse.
Check it out..
Användare som besöker denna kategori: 19 och 0 gäster
